Vinly Sticker Install (HELP)
Old Jan 27, 2008 | 01:20 AM
geoffb123's Avatar
geoffb123
Default Vinly Sticker Install (HELP)
So I im ordering a vinyl sticker from kilingsdesgin. It has 2 horns on either side of the wording and inbetween horns it says "Black Devil". Thought it would suit the black truck. I read the post about installing these things. How the wet install is better and the dry install is worse etc. I do have the tonneau cover and the vinyl is going overtop of it and down both sides of the truck. So my question is.
Wet or Dry?
With the wet install you use a bottly of warm soapy water if im not mistaken?
Also what other tools are needed. I know a puddy knife or squeege. But is there anything that works better then other?
Thanks
This is the vinyl (blue is my favorite color )
http://s79.photobucket.com/albums/j1...rrent=horn.jpg
Old Jan 27, 2008 | 10:52 AM
imnothot02's Avatar
imnothot02
Default RE: Vinly Sticker Install (HELP)
use a mild soap like a teaspoon to a gallon, get bondo scrapers, (this is what i use for tint also...) i get some alignment points marked out on the backing of the stickerw/ a sharpie if its going on a window, in your case i would use a dry erase pen... (bnothing worse than a non centered sticker) douche the whole area with soap water place the sticker move it start in the middle and drag out all the water and bubbles let it sit for a hour...... the glue has to set
then peel the back front backing off, any bubles use a exacto knive put a realy small ***** in the vynyl to get em out, ur done!
Old Jan 27, 2008 | 10:57 AM
jonnymagnum's Avatar
jonnymagnum
ya, I put mine on myself. just do what he said and it is pretty easy. I just used a credit card to smooth mine out, and use baby soap and water for the mixture.
Old Jan 27, 2008 | 11:42 PM
rred's Avatar
rred
i've been told to use the green windex. my cousin uses it with tinting windows.
Old Jan 28, 2008 | 07:42 AM
imnothot02's Avatar
imnothot02
that works too just water will work, but it sticks easier w. just water..
Old Jan 28, 2008 | 11:54 AM
geoffb123's Avatar
geoffb123
Thanks for all your help guys. So from what your saying is that it sticks easier with just water?
Old Jan 28, 2008 | 07:17 PM
imnothot02's Avatar
imnothot02
no use the soap, water it will somtimes stick before you want it to
Old Jan 28, 2008 | 08:12 PM
rred's Avatar
rred
deff use soap or green windex.
Old Jan 28, 2008 | 08:51 PM
peyotecoyote's Avatar
peyotecoyote
The bondo paddle is the best scraper,just remember to pull your truck inside the night before. Oh,yeah and 2 or 3 beers affects your judgement way more than you think.
Old Jan 28, 2008 | 09:19 PM
rred's Avatar
rred
to add to what peotecoyote said, make sure you let the glue cure at a descent room temp if you can. i'm not sure what the climate is like where you are. but the glue is gonna need a 4-6hrs to cure right.
