front end conversion
Old Jan 28, 2008 | 07:44 PM
dodgedakota98luver's Avatar
dodgedakota98luver
Default front end conversion
ok i'm sick of these trucks cheaply made front ends and i'm trying to decide whether i want to do a straight axel conversion or swap out the CVs for U joints tear out the torsion bar crap and put in coil springs. I'm a machinist so custom fabrication is not an issue to me and i'm not pressed for time so what do you all think?
Old Jan 28, 2008 | 09:23 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: front end conversion
I would do a SAS then it will be almost bullet proof
Old Feb 26, 2008 | 11:06 PM
jay_d's Avatar
jay_d
if you can use a torch or plasma cutter and can find a dana 60 you should be in bussiness
Old Feb 26, 2008 | 11:22 PM
spencea15's Avatar
spencea15
I would do a SAS converson, that would be sick.
Edit: I have been told that a mid 70 ford bronko has the same width axle and for servale years they came with dana 60. The axle is like 1in longer (from hub to hub) and the fram rails are the same width. I do not know how true this is but let use know how it goes.
Old Feb 26, 2008 | 11:45 PM
TheePlaymaker's Avatar
TheePlaymaker
definitaly solid axle that is the main thing i miss from my old cherokee is the solid front and rear axles i could hit any pot hole bump or obstical and never had to have the thing aligned and nothing ever broke. let us know how it goes if you decide to because i'd be real interested in hearing how it turns out.
Old Feb 27, 2008 | 06:53 AM
ricbrk's Avatar
ricbrk
I'd like to know a way of doing it also, as two steering racks, one power steering pump, one intermediate shaft, and now it sounds like something else is going, "they think it might be a ball joint", on an 04 with 37,000 miles is nuts. Especially on a truck that has never been off road. Chrysler engineers must have been on a bender when they designed this junk.
Old Feb 27, 2008 | 09:53 AM
Twiztid's Avatar
Twiztid
If your gonna do it, do a SAS. I am currently collecting parts to do mine. I am will be using 76-79 f250 axles. (dana 44 front/dana 60 rear)
only thing I havent decided yet is how to hang em....leaf springs like:
http://www.4x4wire.com/feature/99dakota/solidaxleswap/
or 4/5 link setup like:
http://thurenfabrication.com/arthursrig.html
There are bits and pieces of info out there on this change over.....there is also a guy in the world running a CTD and SAS in his dakota, very nice setup, alot of work. If I find the link I'll post it.
Old Feb 27, 2008 | 10:55 AM
varsis's Avatar
varsis
i don't know much about suspension but I would say the leaf spring set up looks more solid, and probably easier to fabricate up.
Old Feb 27, 2008 | 01:24 PM
BadBenz94's Avatar
BadBenz94
Excuse my ignorance, but what does SAS stand for?
Chris
Old Feb 27, 2008 | 01:54 PM
rred's Avatar
rred
solid axle swap i believe.
that's awsome!
a future project indeed
