Transmission fluid capacity
Old Jan 28, 2008 | 10:20 PM
dakotajeff's Avatar
dakotajeff
Default Transmission fluid capacity
Hey all ,
Can someone tell me how many quarts of fluid my tranny takes .
99 Dak 5.2 4wd auto
much appreciatied
Jeff
Old Jan 28, 2008 | 10:28 PM
imnothot02's Avatar
imnothot02
Default RE: Transmission fluid capacity
gl3 fluid you doin a drop or a flush on it?
Old Jan 28, 2008 | 10:52 PM
dakotajeff's Avatar
dakotajeff
no flush just drop the pan , change the filter and refill
Old Jan 28, 2008 | 10:59 PM
imnothot02's Avatar
imnothot02
next question...what tranny... its between 4-6 quarts
Old Jan 29, 2008 | 12:43 AM
dakotajeff's Avatar
dakotajeff
not sure, 4 spd auto . 99 5.2 ,so 44RE??
Old Jan 29, 2008 | 02:14 AM
varsis's Avatar
varsis
my 42 re was 4 quarts. Im sure it will be close.
Old Jan 31, 2008 | 01:38 AM
sgratto96's Avatar
sgratto96
my 4.7 tranny (45rfe) took 5 1/2 quarts before it was full but i need to check it again. measure whatever amount you get out after dropping the pan and filters, than put that amount in. warm up the engine and tranny and while it is RUNNING and on level ground pull out the dipstick to see what its at. from there you should need to add 1/2 to 1 more quart. thats how mine was so good luck!
Old Jan 31, 2008 | 11:57 PM
dhvaughan's Avatar
dhvaughan
46re will take about 6. start with 4 and check it, then 5, etc. you MUST check the fluild with engine running and shift lever in Neutral NOT Park. one of the pumps doesn't run in park. be sure and use ATF+4 for chrysler do NOT use dexron III
Old Feb 10, 2008 | 10:56 PM
sgratto96's Avatar
sgratto96
my 45rfe took 6 before it was completely full. measure what comes out including what u get out of the filters and than put that amount back in. u will probly have to add from there cuz like i said mine took 6. but the rfe is a bigger tranny than the 5.2 and 5.9 tranny so yours might take less
Old Oct 18, 2013 | 01:49 PM
Jibarra77's Avatar
Jibarra77
Hey guys. I want to drop my 45rfe transmission and install a transgo shift kit on my 04 dodge Ram 1500 2wd 5.7 hemi. How many quarts do you think I need to fill back up. Thanks for the help.
