Front Brakes
Old Feb 7, 2008 | 05:41 PM
lone_wolfin's Avatar
lone_wolfin
Default Front Brakes
Anybody else think the fronts dont work as much as the rears?
My anti-lock (rears) go crazy when it is wet out....
then when therears release (due to a tires locking up) the fronts do verry little in slowing the truck down.
By the way the truck is an 02 QC Dakota.
I looked and have no proportioning valve....
the front pads look fairly new...
maybe the previous owner put on some CHEEP crappy non-metalic generic pads.
anybody else this problem where the fronts dont grab enough??
TIA
Old Feb 7, 2008 | 05:56 PM
Chris's Avatar
Chris
Default RE: Front Brakes
FYI, front breaks do 80% of the braking.
Old Feb 7, 2008 | 06:12 PM
lone_wolfin
correct....fronts should do the majority of the braking, but it seems like the back to the work and when they release, then the fronts aren't doing much (on mine anyway).
What are the front pads suppose to be??.....metalic, semi-metalic??
Old Feb 8, 2008 | 04:21 PM
imnothot02's Avatar
imnothot02
whatever ya like!
sounds like you need to do a brake job and bleed ur brakes to me..
