Front end issues
Old Feb 19, 2008 | 11:01 PM
Hogfan1959's Avatar
Hogfan1959
Default Front end issues
I have a '98 Dakota 4WD Supercab with a 318 and auto. My issue is when I apply the brakes while driving, the truck jerks hard to the right. If I let off the brakes, the truck dives back to the left, but not quite as hard. I've replaced both front axles, both upper ball joints, and had the transaxle checked. I've also removed the front drive shaft, all to no avail. Any help would be greatly appreciated.
Old Feb 19, 2008 | 11:20 PM
TheePlaymaker's Avatar
TheePlaymaker
Default RE: Front end issues
not trying to sound like a jerk but did you get the brakes checked out or changed out maybe their causing you some problems.
Old Feb 19, 2008 | 11:25 PM
OneBadKota's Avatar
OneBadKota
ORIGINAL: pitkanen44flyers
x2
I would start with the brakes first. Can cause pulling when bad.
Old Feb 19, 2008 | 11:36 PM
master tech's Avatar
master tech
Site Moderator & Tech
You may have a rubberbrake line that has collapse on the inside. Or a caliper piston sticking.
Old Feb 20, 2008 | 09:18 AM
4x4kota's Avatar
4x4kota
ORIGINAL: master tech
^+1 To all the above suggestions. Do we have a proportioning valve? If so it could be FUBAR'ed.
