HID PROBLEM
Old Feb 24, 2008 | 12:36 AM
dakotaballin313's Avatar
dakotaballin313
Default HID PROBLEM
ok so i bought xentec hid kit off ebay from some guy that clames he has a store but doesnt asnwer emails for 4 days... the kit came with a power (red wire) and a balck wire with another black one on it. i can with the connector for my truck but when installed the stay on if i have the headlights on or not? i checked the relay i tried one side hid and other side reg. blub every wire way i can get out of it still dont work. one of the other wire way i get flickering from the hid blub. here is some pics maybe they will help... any one with ideas PLEASE reply or comments aswell 6093842200 Dakotaballin313@yahoo.com or on the forums.. thanks to all....
This is my wiring diagram if you think i need to do something different please tell me..
This is what i recived blubs are different tho.. also on the connecters was a black wire off of the other black one to the plug which is blue and connects to a 2000 dakota the three wire plug
Old Feb 24, 2008 | 03:03 PM
rtkota5point9's Avatar
rtkota5point9
Default RE: HID PROBLEM
You should use relays for one thing, don't just connect them to the factory wiring. Even if it says youcan, the factory wiring doesn't have enough "sack" to power em up reliably.
Old Feb 25, 2008 | 12:53 AM
geoffb123's Avatar
geoffb123
Someone else on this forum bought HID's off ebay. They said that they only lasted about 1 month, and even the wiring was wrong. Not trying to scare you. But it seems like on ebay, if you want HID's you gotta fork over close to 200.
Old Feb 25, 2008 | 01:04 AM
OneBadKota's Avatar
OneBadKota
ORIGINAL: geoffb123
Not true, I paid under 200 for my headlights and fog lights. Just need to know where to look. Also, HidKitsWarehouse.com has some good deals.
That wire set up on the right should be with the bulb, and plug into the ballast. 3 should connect from the bulb to ballast. It should really be a plug-n-play set up. Only thing to mess with on original harness is the plug from the HID to the plug to the original harness.
I'm not familar with the ones you have, they look totally different. Might not be P-N-P and I wouldn't trust getting more into the original harness than just a plug in. IMO
Here's what mine look like..
These are for the fogs, only difference is the two prongs replace the blue plug in on a headlight kit.
Old Feb 25, 2008 | 02:22 AM
geoffb123's Avatar
geoffb123
Well a decent amount of money though. Some kits are around 50$ on ebay. Those are the ones that don't seem to last.
