04 dakota misfire
Old Feb 26, 2008 | 08:32 AM
crayfish's Avatar
crayfish
Default 04 dakota misfire
First detected a P0304 cylinder #4 misfire. Swapped coils on cylinder #4 and 6. Subsequent codes were P0300 (random misfire) and P0304. If the original #4 coil was bad, why did 0300 pull instead of 0306 after the swap??
thanks
Old Feb 26, 2008 | 09:46 AM
jdl's Avatar
jdl
Default RE: 04 dakota misfire
My guess is the computer already had the #4 misfire, you switched the coils, then it saw a #6 misfire. In the computer memory it had both the #4 and #6 misfire, to the computer that meant random misfire. I'm not sure I worded that correctly?
If you had erased the first code before you swapped the coil, I'm not sure if you would have only got the #6 misfire instead of the random code? Interesting
Old Feb 26, 2008 | 03:06 PM
varsis's Avatar
varsis
check your spark plug wires that causes problems.
Chris
Old Feb 26, 2008 | 05:27 PM
04firedak's Avatar
04firedak
the dakotas dont have wires so to speak they each have individual coils on each spark plug...its weird
Old Feb 26, 2008 | 08:19 PM
BlackOut04's Avatar
BlackOut04
Its called coil on plug. i would swap the plugs if i were you. otherwise besides the coils themselves you may be looking at an injector.
