added some reverse lights.
Old Feb 27, 2008 | 10:40 PM
BlackOut04's Avatar
BlackOut04
Default added some reverse lights.
i have tinted windows so at night the regular reverse lights dont light up much so i added some extra reverse lights.
[IMG]local://upfiles/81574/56CACE38BB4C42F392F4428E504F295B.jpg[/IMG]
[IMG]local://upfiles/81574/0A30369BB2AD4907BC8DF059E73EE321.jpg[/IMG]
Old Feb 27, 2008 | 11:16 PM
TheePlaymaker's Avatar
TheePlaymaker
Default RE: added some reverse lights.
looks sweet i've always liked the idea of extra back up lights...maybe ill have to add some to mine this summer.
Old Feb 27, 2008 | 11:19 PM
BlackOut04's Avatar
BlackOut04
Yeah it helps alot. i didnt have to cut or drill anything to mount them. there were holes right under the license plate frame. so it worked out nice. cost me a total of about $30 for the lights and some extra wire, tape, and solder.
Old Feb 28, 2008 | 12:51 AM
300exoh's Avatar
300exoh
So did you just tie them into the stock wiring? Did you use any kind of relay or anything?
Also what type of lights did you use? Wattage?
I have thought about doing the same thing but I don't want to overload the factory wiring. It would make it much easier to see since I live in the country and it's very dark at night plus the tint doesn't help.
Thanks for any info...
Old Feb 28, 2008 | 09:21 PM
BlackOut04's Avatar
BlackOut04
i bought a $20 fog light kit from Advance Auto and tied them into the reverse light wiring. i didnt use a relay or a fuse. im not worried about overloading it because it the reverse light and they are only on when in reverse. if it was a light that was one constantly then i wouldve used a fuse.
Old Feb 28, 2008 | 09:27 PM
geoffb123's Avatar
geoffb123
Not a bad idea. Im going to eventually end up doing that. I just can't find out how to get my reverse lights working. Everytime I go into reverse the lights never come on and the fuse ends up blowing. Im not sure really whats happening. And before they were working but only when I had the shifter down to when im almost in "N". I wanted to get some LED reverse lights and then possibly do that too. Just have to start with the problem of the lights not working though.
Old Feb 28, 2008 | 09:30 PM
BlackOut04's Avatar
BlackOut04
i can get a wiring schematic of the lighting system if you need it. sounds like a short but im sure you know that. just a matter of where. i would probably start in the column.
Old Feb 28, 2008 | 11:40 PM
TheePlaymaker
i think there is also a thing called the neutral safety switch or something that goes bad...its a common problem with jeeps and i read about it on the daks to somewhere i believe it causes the reverse lights to not come on either altogether or unless you wiggle the shifter. but it also sounds like it could be a short since its blowing fuses just wanted to add something else incase that wasn't your problem.
Old Feb 29, 2008 | 12:56 AM
geoffb123's Avatar
geoffb123
Well a while ago my park lights kept on going out. So I looked underneath the bumper and I found what looks like a cheap way out of fixing something. Looks like the owner before me took electrical tape and put it around the wires leading up to the park lights/reverse lights. Also where it grounds out, it seems like the ground was coming loose. So i'll start there for the first part, then get the neutral safety switch, I was told it was that before, but now before I fix that I have to fix this ground issue. But thanks guys, your a great help.How hard is it to change out that switch. I was reading up on it and its underneath the drivers side tranny.
Old Feb 29, 2008 | 03:31 PM
rred's Avatar
rred
nice. i just bought arear bumper gaurd off ebay for 10 bucks.i plan on mounting a nice set off flood lights. but ill probably run them on a toggle. that way i can use them when with just the flip of a switch.
