quick question
Old Mar 3, 2008 | 05:46 PM
justin316's Avatar
justin316
Default quick question
I got a 1999 dakota 5.2L and i'm trying to figure out where the flasher relay goes in. In the fuse panel by the drivers side there looks like a relay in there, would this be it or should i look somewhere else.
thanks.
Old Mar 3, 2008 | 06:26 PM
spencea15's Avatar
spencea15
Default RE: quick question
under the hood by the battary i believe.
Old Mar 3, 2008 | 11:45 PM
jonnymagnum's Avatar
jonnymagnum
its on the drivers side of the dash. pull the lil pannel off and its in there. there is a diagram on the back of the pannel to tell you where it is.
Old Mar 4, 2008 | 07:20 AM
bigbucks1120's Avatar
bigbucks1120
all your relays are under the hood just behind the battary pull the lid off and look for the flasher relay but remember lookin at the panel to find them its like lookin inmirror so they are backwards all your fuses for cig lighter and stuff like that are on the drivers side when you open the door by the dash but i would suggest checkin your fuses first the relays are a pain in the rear!
Old Mar 4, 2008 | 02:34 PM
justin316's Avatar
justin316
ok now i'm more confused then ever, some people are telling me its under the hood by the battery and others are telling me it's in the steering colum and others are telling me its by the other fuses on the drivers side fuse panel? So if anybodys changed one of these before fill me in.
Old Mar 4, 2008 | 03:09 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
ok here it is
the relays are under the hood, just behind the battery
the fuses are in the dash panel when you open the door you can see the fuse box
and the flasher switch is in the column(duh) im not 100% sure what you are trying to change, but the first two have labels on the covers for the relays it is mirrord and for the fuses its on there just turn it until it matches up hope i helped
Old Mar 13, 2008 | 08:52 PM
justin316's Avatar
justin316
ok i still haven't found it, on the drivers side there is a fuse panel with what looks like a blue colored relay is this it? i took off the steering colum cover and could not find it in there, it will not fit under the hood by the other relays. anyone know?
Old Mar 14, 2008 | 01:40 AM
BlackOut04's Avatar
BlackOut04
You could check under the dash around where the OBD port is. im asuming your flashers arent working? try your 4 ways, if you hear them click then look for where the clicking is, the relay is whats causing the clicking. alot of times the directional relay is by the 4 way relay.
Old Mar 14, 2008 | 01:49 AM
Frenchy's Avatar
Frenchy
Whenever someone says "quick question" do you guys read the post realllly fast, and all the replies really fast as well, to save time?
...i do...
And then I try and type really fast...
Orrrrr, I'll say "Quick question? Slow answer..."
Old Mar 14, 2008 | 02:06 AM
BlackOut04's Avatar
BlackOut04
are you saying what I said doesn't make sense?
