Front end noise
ORIGINAL: 01dakv686
was this your hub or wheel bearings? Are they seperate pieces or do you have to buy them as one?
Yeah, I unfortunately waited to long to change it. Melted the god dam plastic thing on the spindle nut. Then had to go to the dealer ship to get a new one. But that noise was soooooooo annoying.
This is what happens when your wheel bearing goes completely
http://checktechltd.com/Truck/
The passenger side front is where it went. Check it out , pretty nuts what can happen.
ORIGINAL: varsis
I have this same problem in my first gen. The noise goes away when I the brakes. I need to replace the hub assembly and wheel bearing? It only seems to do it when I turn left. Do they both come in one unit on a first gen?
