Keep it???? or replace
ok so i had a super delta flow 40 series on it and it sounded waaaaayyyyyyy toooo ricey in the higher rpm range....so i changed it and have had this IMCO glasspack on for a few months now and i'm not sure if i like it
lemme know what you think
all opinions welcome
http://s162.photobucket.com/albums/t...t=P1120472.flv
and if you think i should replace it leave a suggestion
thanks
thanks
it doesn't sound horrible if your driving a little car but i think you need something that will give you a little deeper sound like a flowmaster 40 or 50series.
slowmasters flow like **** and not sure if you have a 6 or not but a 40 series would sound just as ricey if not more than a delta most likely, hooker aerochamber is a chambered muffler but i could see right through mine to the other side it also cancells out higher frequencys so all you get is a nice rumble. or something like a magnaflow or borla would make it rumble really good.
yep 3.7 v6.....
and i dont have the 3.9 lol
i did see a vid of a 3.7 with a 50 on it...lemme find the link....
http://s33.photobucket.com/albums/d7...t=MOV00263.flv
didnt think it sounded too bad
but anyone got a clip of the hookers or borla on a 3.7?
ORIGINAL: pitkanen44flyers
dude, thats about as good as you can get a v6 to sound, anything else is going to be a waste of money. My dynomax 3" catback sounds about like that, except a little deeper at idle.
Trending Topics
ORIGINAL: MTN13
I went on youtube and found a video of that exhaust and i must say it does sond better than the flowmasters. Is that your video on youtubepitkanen, it looks like the one in your sig, if so very nice sounding truck and very clean i like it!
Delta flow sounds good on a 4.7. Magnaflow sucks. "Going to here it on that, LOL". Borla's are worth more than the trucks, why waste the money. I'd invest in a good Amp, and speakers, then go to the drag strip and record the drag racers. When someone pulls up next to you, put the tape in, crank up the volume, and make them wonder whyyour truck sounds like it is goin a hundred sitting at the red light. Not only that, you can listen to good music when not playing the exhaust. See, kill two birds with one stone. OK, I was going to pass this one by but didn't, so let me have it. Hey pitkanen, your truck does sound good on Utube.
