99 Dak 2WD Wheel bearing replacement...
I've got something you all should like. I'm not sure if it's because it's a 4X4 hub or the nut is just seized. I've got a hub nut that just won't budge, I've used air with an impact wrench(250ft-lbs). I've hit it with liquid wrench type of stuff. I've a breaker bar that snapped beacuse of this nut.
I got a price for the job before I started and the shop told me $196 just for the hub. Then 2hrs labor. $120 buck. So I figured out that the hub only has 3 bolts to swap it. Sounds easy enough. Except for that b!tch of a nut.
Next I'm thinking angle grinder.
Any suggestions?
Thanks
Any suggestions?
Thanks
