starter wiring issue
Old Mar 22, 2008 | 09:33 PM
magnethead's Avatar
magnethead
Default starter wiring issue
I don't know if this is a rehashing, but we found out the hard way that dodge wired a key starter power line in an unfastened position right next to the power steering pulley. The wire leaned over, the pulley rubbed through the insulation, and blew the 50 amp fuse in the fuse block under the hood. Might want to go peak and see if you're ready to get stranded with no power to the starter like i was today. (on lunch, even better)
Old Mar 23, 2008 | 01:36 AM
imnothot02's Avatar
imnothot02
Default RE: starter wiring issue
mm mnot on mine..
