More Codes
Old Mar 25, 2008 | 07:43 PM
crayfish's Avatar
crayfish
Default More Codes
While investigating a CEL and playing with a friends scanner I came up with the following codes. P0100, P0012, P0004, P4800. Can anyone help decipher these?? I can't seem to find them on the web. The 0004 and 4800 cleared and didn't return but the others are still hanging around.
thanks
Old Mar 25, 2008 | 10:25 PM
JasonA's Avatar
JasonA
Default RE: More Codes
I'm not sure what the P0012 is. I mean, it's a valid code, but don't think it applies here. The definition for the code is: "Camshaft Position Actuator A - Bank 1 Timing Over-Retard". No 2nd generation Dakota has variable valve timing, so I'm not sure why you're getting that code. P0100 isdefined as a "MAF or VAF A Circuit Malfunction". I'm not sure which of these trucks have MAFs (my '97 does not), but yours might. A model year would be helpful. Any driveability symptoms?
Old Mar 27, 2008 | 01:21 PM
crayfish's Avatar
crayfish
2004 Dakota Quadcab 4.7 V8. Seems to drive ok, maybe a little rough when climbing hills. At an idle it feels like it might be skipping but it hasn't reduced my gas mileage by much if any.
Old Mar 27, 2008 | 02:03 PM
JasonA's Avatar
JasonA
You are able to completely clear all the codes with the scanner, yes? Even with the ignition "off", I can hook the scanner up to my '97 and read and clear codes. I would try again to clear them all and see which come back, and under which conditions.
For example, if one comes back as soon as you turn the ignition on (engine not started), it's a good possibility that it's electrical. If the engine has to run for a while before the code appears, it's more than likely a lazy part that corresponds with that particular code. I'm particularly curious about your P0100, which is the MAF sensor circuit. Does your truck have a MAF sensor? I would check the connection and the wiring to that sensor.
Old Mar 28, 2008 | 09:05 AM
crayfish's Avatar
crayfish
I can clear the codes with engine running and the skipping seems to smooth out right away. After only a few seconds the skipping comes back and so do the two codes. I'm not sure about the MAF. I got to get a book for the truck since it's out of warranty.
thanks
Old Mar 28, 2008 | 09:22 AM
JasonA's Avatar
JasonA
Even though the 2004 4.7L engine doesn't have variable valve timing, it certainly has at least one camshaft position sensor, and that appears to be what the P0012 code is. I'm not familiar with the 4.7L engine, though, so someone else is going to have to help you out on that. The P0100 code is for the MAF, and it should be relatively easy to check for a connection/wiring problem. Look carefully at the MAF sensor connection, maybe pull it out and re-connect it a few times. There may be a piece of dirt in there or something. You can even put a SMALL amount of dielectric grease in the terminals to stave off moisture and corrosion. That type of connector is usually a "weatherpack" connector (with a rubber seal), but stuff still gets dirty over time.
