Tranny Problem
Old Mar 26, 2008 | 04:08 PM
Canadian Fijian's Avatar
Canadian Fijian
Default Tranny Problem
when i shift tp drive or reverse from park, as well as from reverse to drive and vice versa, there is a loud whirring/grinding noise then you can a thunk. I just had my tranny flushed and the fluid changed but what could it be. And how can i fix it?
Old Mar 26, 2008 | 06:16 PM
varsis's Avatar
varsis
Default RE: Tranny Problem
Might be your torque converter and the the ujoint.
Old Mar 26, 2008 | 06:48 PM
moe7404's Avatar
moe7404
moe in wichita ks
have your trans man check the check valvein the collent/lube line,it holds junk and stops the folw oftrans fuild. i think it is at the rad. one dude on this forum had it just removed. if you have good trany man get him to put a shift kit in and put two qts of rear end grease in the trany.
direct your trans questions to
Contact: 1-800-835-1007
email orders: parts@areds.com
they will know the answer to ANY question you have, and the best parts. 90% of ALL trans shops get there parts from a & reds. i have known these people from the late 60s, they are honest.
Old Mar 26, 2008 | 08:39 PM
varsis's Avatar
varsis
ORIGINAL: moe7404
moe in wichita ks
have your trans man check the check valve in the collent/lube line, it holds junk and stops the folw of trans fuild. i think it is at the rad. one dude on this forum had it just removed. if you have good trany man get him to put a shift kit in and put two qts of rear end grease in the trany.
Im the one who had it removed. No problems yet. But they cause more problems then save...
