throttle positioning sensor problem?
Old Mar 29, 2008 | 02:33 PM
apbt_phoenix's Avatar
apbt_phoenix
Default throttle positioning sensor problem?
okay so heres the deal. once in a while when i start the truck, itll idle around 2, and itll stick when i rev it.(gas pedal doesnt stick) checked the throttle cable, its fine, had the sensor checked, its at .6, .1 off, and i still have no clue what else it could be. should i just replace the sensor or ?? need some opinions here. thanks.
Old Mar 29, 2008 | 04:03 PM
varsis's Avatar
varsis
Default RE: throttle positioning sensor problem?
Sounds like a vacuum leak...
Old Mar 29, 2008 | 06:31 PM
moe7404's Avatar
moe7404
moe in wichita ks
say varsis what shift kit did you use and how much did the rebuild cost?
Old Mar 29, 2008 | 08:15 PM
varsis's Avatar
varsis
ORIGINAL: moe7404
moe in wichita ks
Im not sure of the exact kit but I know it's a trans go. The rebuild cost me 1,500. Canadian. Like a year ago.. now I think. It kicks pretty hard. No problems yet. it changes how it drives dramatically though. It's a pretty good kit I think. I think it's like stage 1. I got it rebuilt here:
http://highstall.com/
Old Mar 29, 2008 | 09:47 PM
moe7404's Avatar
moe7404
moe in wichita ks
thanks for the info varsis. iam just trying to think ahead about someday needing a rebuild. but at 90000 miles i have been told to not put a kit in. but i think if its in good shape a kit might work. i have been putting two qts of rear end grease in the trans. been doing for years , seams to work fine. i think it gives a thicker oil which means longer life.
