milky oil cap
Old Apr 1, 2008 | 11:54 AM
OneBadKota's Avatar
OneBadKota
Default RE: milky oil cap
If it's the 4.7, they make a PCV relocation kit to stop the issue.
http://dodgeram.info/tsb/2006/25-001-06.htm
Old Apr 2, 2008 | 04:51 PM
CL350RR's Avatar
CL350RR
FYI the baffle that was designed to go into the oil fill pipe does not address the problem, only makes it invisible when you take the cap off. like mentioned, change your oil regularly, remove the baffle and clean it when you change the oil. on mine, it is ugly in the winter months, goes away completely during the summer.
