Door Speaker size?
Old Apr 9, 2008 | 07:30 PM
yz125dakota's Avatar
yz125dakota
Default Door Speaker size?
ive searched and couldnt find anything, i have a 02 quad cab and i want to replace all 4 speakers. I dont have the infinity system in it. i think they are 6.5s right? and how hard is it to pull the door panel off?
Old Apr 9, 2008 | 07:35 PM
NatesDakota's Avatar
NatesDakota
Default RE: Door Speaker size?
Well on my 03 QC their 6.5".....as far as taking off the door panels....its pretty simple....I think its 3-4 screws and lift off....make sure to un-clip the wiring harness for PL/PW and spker itself.....
Old Apr 9, 2008 | 07:49 PM
spencea15's Avatar
spencea15
6.75 but 6.5 will work, they make brackets for 6.5 speakers so you do not have drill to mount the speakers.
Old Apr 9, 2008 | 08:58 PM
NatesDakota
Well....im waiting on an amp still before I put all the stereo equp. in but im going to have to fab up a trim ring of some sort....im going to try and put a set of Alpine 5 1/4 comp. in that hole and putting the tweet in the pilliar....dont think it should be too bad do you?
Old Apr 9, 2008 | 09:17 PM
Dodge Rules's Avatar
Dodge Rules
Our door speakers are 6 1/4 but 6 1/2's will work for speakers. i just replaced mine with some appines. i love the difference they are right on the change and how much better the sound quality is. there are 4 bolts one near the side mirror. one behind the door handle. and two at the bottom. The next thing is to disconnect the rod that is connected to the door handle. You need to either pop the cover off from where the power windows switches come off and disconnect the rod. then the last thing if you have a window crank like mine then you need to take the c- clip off then take the crank you and then take the panel off. you need to make sure that you disconnect the mirror connections and if you have power windows unplug that. After all that it is only three bolts that are holding the speaker in. you should get a bracket with the speakers that you need to mount to it and there should be instructions to do that. there is a connection to the speakers. then all you have to do is put it back together. good luck. if you need some pics i will try my best to get some posted.
Old Apr 9, 2008 | 09:31 PM
spencea15's Avatar
spencea15
ORIGINAL: Dodge Rules
Like i said before the are 6 3/4 not 6 1/4 but 6 1/2's will fit.
Old Apr 10, 2008 | 03:54 PM
02dakotakid's Avatar
02dakotakid
i just replaced mine with a full kicker ss set. i have 6.5 copmonents up front with the crossovers in the door pockets. i had to trim my factory tweeter holes for the new ones. i love them. i put a 650watt amp on them. they absolutely scream. i love it. only problem is that i need a bigger sub cause the highs kind of over power. but its so worth it.
Old Apr 10, 2008 | 06:21 PM
Dodge Rules
ORIGINAL: spencea15
Did not mean to affend. quick typing. not thinking you are right about 6 3/4
Old Apr 11, 2008 | 10:33 AM
Loud Pedal's Avatar
Loud Pedal
The Total Package
i have 6.5 pioneer all aroun and two rockford fosgate P2D2 powered by a 325.1 amp and they pound!!!!! im wanting to put tweets in there too but location it a bit of a problem
