pcv valve
Old Apr 17, 2008 | 08:53 AM
Brummo's Avatar
Brummo
Default pcv valve
Can anyone tell me for sure if my '04 v8 4.7 has apcv valve on it,and where it would be located? I'm pretty sure it does, and haven't looked yet. My old V6 I don't think had one. I could be wrong. It's not unusual sometimes
Old Apr 17, 2008 | 09:26 AM
varsis's Avatar
varsis
Default RE: pcv valve
Look on top of the valve cover, or close that is where mine was on the v6. Replaced it once trying to get rid of a tick...
Old Apr 17, 2008 | 09:33 AM
dcurtis48's Avatar
dcurtis48
On the 4.7 it is located on the oil filler neck, at least that is where it is located on my '03.
Old Apr 17, 2008 | 10:13 AM
Brummo's Avatar
Brummo
thanks, i'll look when i get a chance. Wasn't sure exactly where. It should probably be replaced when I do my plugs. Got 35,000 on the truck.
Old Apr 17, 2008 | 02:03 PM
ricbrk's Avatar
ricbrk
It is located on the oil filler tube under the heater hoses. It is a pain in the [sm=smiley35.gif], to get out if the hoses are hot. It twists loose then you pull it out. Hardest part is fighting the hoses. Don't force it, as everything is plastic down there. Pic 1 shows hoses, and pic 2, thevalve is at the end of my finger.
Old Apr 17, 2008 | 02:27 PM
rpowell's Avatar
rpowell
It is an absolute pain to get out, goes in easy though. I removed the clips that hold the hoses still, spread the hoses apart and took a pair of needle-nose to get mine out. The new one went in pretty easy, but be careful like ricbrk said, its all plastic. Good luck
Old Apr 18, 2008 | 11:54 AM
Brummo's Avatar
Brummo
Thanks I found it last night. Great spot for it son't ya think. Thanks for the help. Do you replace these often?
Old Apr 19, 2008 | 09:59 PM
ricbrk's Avatar
ricbrk
I replace mine every 3rd oil change, as with the sludge problem in the filler neck seems to work it's way into it. They are cheap enough, so why not.
Old Apr 21, 2008 | 08:15 AM
DakinUK's Avatar
DakinUK
Excuse my ignorance but what is a PCV valve and what does it do? I've got a 4.7 with 68k on it and as far as I know its never had a PCV valve changed. Thanks for any info.
Paul.
Old Apr 21, 2008 | 11:46 AM
chris1974's Avatar
chris1974
ORIGINAL: DakinUK
Paul.
Hi Paul.ThePositive Crankcase Ventilation valve, or PCV valve is a one-way valve that evacuates thegases from inside the crankcase. Im not really sure what the manufacturer suggests on replacement, but I replace mine every 10k miles or so. Like someone said before- they are cheap and easy to do.
