PO 340?
Old Apr 22, 2008 | 10:16 PM
pumpkinheaver's Avatar
pumpkinheaver
Default PO 340?
OK so the engine light comes on today. I did the ingnition switch trickand I get a PO 340 and I am told this means-No cam signal at PCM no fuel sync. What exactly does this mean in english?????
Old Apr 22, 2008 | 10:46 PM
varsis's Avatar
varsis
Default RE: PO 340?
ORIGINAL: pumpkinheaver
OK so the engine light comes on today. I did the ingnition switch trick and I get a PO 340 and I am told this means-No cam signal at PCM no fuel sync. What exactly does this mean in english?????
It means you won't get fuel... Because you won't be able to synchronize you cam and crank.
Old Apr 22, 2008 | 11:16 PM
00DakR/T's Avatar
00DakR/T
Default RE: PO 340?
Sounds like a dead or dying cam sensor. No big deal to change for themost part
Old Apr 23, 2008 | 12:29 AM
MTN13's Avatar
MTN13
From: Hometown= Highland Michigan School= Lima Ohio
Default RE: PO 340?
not sure what engine you got but i took 10 mins to change the sensor. it took me longer to find it then to change it.
Old Apr 23, 2008 | 05:23 PM
pumpkinheaver
Default RE: PO 340?
Thanks for the replies folks. I have the 3.9L engine.
Old Apr 23, 2008 | 07:20 PM
00DakR/T's Avatar
00DakR/T
Default RE: PO 340?
With a 3.9 its under the distributor cap. Looks more like a pick-up coil than a cam sensor, but...
Old Apr 26, 2008 | 11:35 AM
pumpkinheaver
Default RE: PO 340?
But.....what?
Old Apr 29, 2008 | 09:26 PM
00DakR/T's Avatar
00DakR/T
Default RE: PO 340?
its a cam sensor
Old Apr 29, 2008 | 11:13 PM
varsis's Avatar
varsis
Default RE: PO 340?
Heh, cam sensors are easy the crank ones are the pain...
Old May 2, 2008 | 04:36 PM
pumpkinheaver
Default RE: PO 340?
Does the cam sensorhave a different name? I was gonna order one but I can't seem to find it on the autozone or o'riley's website under that name.
