Few questions about my Dad's Dakota
Old Apr 25, 2008 | 04:40 PM
kowboydmac's Avatar
kowboydmac
Default Few questions about my Dad's Dakota
1998 2wd single cab 3.9L
- The interior overhead light does not come on
- The speedometer doesn't work (can't find my original thread when I asked, no time to search right now, lol)
- What kind of tune-up would give a 3.9L the best mpg? I don't care about hp, I've got the v8 for that, but I would like his 3.9L DAK to push 17mpg. Possible?
Old Apr 25, 2008 | 06:53 PM
varsis's Avatar
varsis
Default RE: Few questions about my Dad's Dakota
ORIGINAL: kowboydmac
Well the 3.9 gets close to the 5.2 for millage. usually worse, from what I have heard.
The 17 is possible though. Not sure about the light, I would guess a ground wire for the speedo...
Tune:
Seafoam Depending on Millage(Intake and Gas)
Wires
Plugs
Cap
Rotor
Clean some sensors new PVC.
Old Apr 25, 2008 | 08:37 PM
wink2873's Avatar
wink2873
check your rear wheel speed sensor, that usually causes the speedo to quit working. just get a brass cap and rotor and good wires, new plugs, seafoam it, new air filter, oil change and filter. the best way to get good mileage is to never go past half throttle unless you have to. My 3.9 can get up into the 20's.
Old Apr 26, 2008 | 06:36 PM
kowboydmac's Avatar
kowboydmac
I noticed today how similiar the layout is for the 3.9L my 5.9L. Are some of those parts interchangeable? Looked to me like the accesory bracket, alternator, idler pulley could.
Ok, good to know it's a fairly common tuneup. Thanks.
Seafoam is good stuff, I ran that in my Ram when I first got it. Blew out a big ol smoke cloud, lol.
I'd rather not go get a haynes for my dad's Dak, so can you explain or show me a pic of this rear wheel sensor?
Old Apr 26, 2008 | 07:32 PM
varsis's Avatar
varsis
Yea the 5.9 is pretty much the same motor, just two more cylinders. I just did this swap, and it worked out pretty good just tying some loose ends like my transmission which won't work properly...
Old Apr 27, 2008 | 09:13 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
umm the speed sensor is the only electrical wire going to the top of the rear differential, you can miss it just put the truck on jack stands and slide under it and you should be able to see it
Old Apr 27, 2008 | 11:21 AM
kowboydmac's Avatar
kowboydmac
Does it replace like an o2 sensor? or is it held in by screws?
Old Apr 27, 2008 | 12:46 PM
shrpshtr325
THE ULTI-MOD
its held onto the rear differential by a bolt, and its not like an 02 sensor its a magnet that reads how many times the dear goes around to calculate the mph from rear axel RPMs
Old Apr 27, 2008 | 07:27 PM
kowboydmac's Avatar
kowboydmac
ok thanks. i'll go check on the cost of the sensor. shrpshtr, what is ktown, nj? i use to live in ktown, FL lol (kissimmee)
Old Apr 28, 2008 | 03:08 PM
shrpshtr325
THE ULTI-MOD
umm kinnelon its a small town population wise i go to a high school of at most 600 kids and its a typical NY suburb basically , one of the more well-off ones but still
