Transmission Solenoid..
Old Apr 26, 2008 | 07:31 PM
varsis's Avatar
varsis
Default Transmission Solenoid..
Does anyone know why this won't work? I have plugged and unplugged the blue ish plug twice without any luck.... Any ideas? I can't shift except for 2nd and third.... (Still okay to drive but would like my other gears...)
Old Apr 26, 2008 | 07:45 PM
moe7404's Avatar
moe7404
Default RE: Transmission Solenoid..
moe in wichita ks
get in touch with these guys. i have known them from the 60 s they are honest. 90% of ALL trans shops get parts fro a & reds. they will know the answer to any question.
Contact: 1-800-835-1007
email orders: parts@areds.com
Old Apr 26, 2008 | 08:08 PM
dodgerules86's Avatar
dodgerules86
[align=left]From the service manuaL:[/align][align=left][/align][align=left]NO LOW GEAR (MOVES IN 2ND OR 3RD GEAR ONLY)[/align][align=left]1. Governor Circuit Electrical Fault. -- Test with DRB® scan tool and repair as required.[/align][align=left]2. Valve Body Malfunction. -- Remove, clean and inspect. Look for sticking 1-2 shift valve, 2-3 shift valve, governor plug or broken springs.[/align][align=left]3. Front Servo Piston Cocked in Bore. -- Inspect servo and repair as required.[/align][align=left]4. Front Band Linkage Malfunction -- Inspect linkage and look for bind in linkage.[/align][align=left][/align][align=left]Have you tried disconnecting the PCM and trying again? I'll do some searchin and look through the tech books I have to see if I can find anything more.[/align][align=left][/align][align=left]Oh yea, any check engine light? Might want to pull the codes anyways, however.[/align]
Old Apr 26, 2008 | 08:30 PM
varsis's Avatar
varsis
ORIGINAL: dodgerules86
[align=left]From the service manuaL:[/align][align=left] [/align][align=left]NO LOW GEAR (MOVES IN 2ND OR 3RD GEAR ONLY)[/align][align=left]1. Governor Circuit Electrical Fault. -- Test with DRB® scan tool and repair as required.[/align][align=left]2. Valve Body Malfunction. -- Remove, clean and inspect. Look for sticking 1-2 shift valve, 2-3 shift valve, governor plug or broken springs.[/align][align=left]3. Front Servo Piston Cocked in Bore. -- Inspect servo and repair as required.[/align][align=left]4. Front Band Linkage Malfunction -- Inspect linkage and look for bind in linkage.[/align][align=left] [/align][align=left]Have you tried disconnecting the PCM and trying again? I'll do some searchin and look through the tech books I have to see if I can find anything more.[/align][align=left] [/align][align=left]Oh yea, any check engine light? Might want to pull the codes anyways, however.[/align]
I get codes for like everything. Im not sure if the control is seated properly... ect.. I had some severed wires on the harness but repaired them maybe they came loose? I tied them and put soder on them. held pretty good when try up top... But I do have 2nd and 3rd gear...
This is because of my swap btw. Everything else except the speedo works...
Old Apr 26, 2008 | 09:24 PM
Bad96_3.9's Avatar
Bad96_3.9
did you change computers with the swap?
Old Apr 26, 2008 | 09:37 PM
varsis's Avatar
varsis
ORIGINAL: Bad96_3.9
Yea, but the plugs are the same...
Old Apr 29, 2008 | 01:53 AM
varsis's Avatar
varsis
Just a thought, Would a ground wire affect this? I noticed three on this harness my other one had 2 but I had to cut it, Would the ground wire do anything>
