new headlight bulb help?
Old Apr 30, 2008 | 05:56 PM
aed208's Avatar
aed208
Default new headlight bulb help?
Can someone please tell me the easiest way to install new lightbulbs in my dakota? I just bought new halogens and i wana put them in but i cant figure out how to get the old ones out? Please help me thanx
Old Apr 30, 2008 | 05:58 PM
batman13's Avatar
batman13
Default RE: new headlight bulb help?
you may want to search for it, its a common question
but simply, you can get to the bulb from behind the fender, reach under from the engine bay
Old Apr 30, 2008 | 11:46 PM
00DakR/T's Avatar
00DakR/T
If you look between the turn signal piece and the headlight piece there is one little star bolt. I think its a t15. Anyway, if you take that bolt out the turn signal piece will swing out of the headlight assembly and you can get to the 4 bolts that hold the headlight in. The passenger side isn't too bad to do with the headlight still in the truck, but the passenger side is definately easier done this way than taking the battery out.
Old May 1, 2008 | 07:44 AM
mplue's Avatar
mplue
I've replaced my headlight bulbs and didn't have to take the headlights out. Seemed like I just disconnected the connector and give the bulb a 1/4 turn and it came out of the headlight assembly. Not sure if that is the proper way, but it worked for me.
Old May 1, 2008 | 10:11 AM
JasonA's Avatar
JasonA
I changed the headlights in my '97 also, no disassembly or battery removal required. It's just a quarter turn of the retaining ring like mplue said and they slide right out.
Old May 1, 2008 | 10:13 AM
Loud Pedal's Avatar
Loud Pedal
The Total Package
look inside the fenders behind the headlights and disconnect the wires(plug in)
rotate the ring countor clockwise
and when you get the ring off
wiggle the bulb and it comes out without turning it
Old May 1, 2008 | 02:38 PM
batman13's Avatar
batman13
i need to take mine out to replace them....
but they're aftermarkety so i get what i deserve
Old May 1, 2008 | 03:04 PM
wink2873's Avatar
wink2873
if you have small enough hands you can take them out from the inside by reaching through the small hole near the fender. I couldnt even get half of my hand in there so I had to take the whole damn thing off. Now it points furter towards the ground than it should.....stupid thing
Old May 1, 2008 | 09:57 PM
00DakR/T's Avatar
00DakR/T
I would have to say that I have big hands, and just couldn't handle the small spaces haha
I put my HID's in on my lunch break one day, and that was with pullin the driver's side headlight assembly out
Old May 2, 2008 | 12:13 AM
aed208's Avatar
aed208
thanx for the input ill give it another try i just got really pissed off and frestrated and gave up cause i have big hands as well but ill give it another go ahah
