PLUG change
Old May 2, 2008 | 10:18 AM
Brummo's Avatar
Brummo
Default PLUG change
Just did a needed spark plug change last night. Not a bad job thanks to DC. The only plug that was a pain was #8. The rest were easy. Got a new PCV valve in, that was pretty easy as well. Not bad for a 1 hour job.
Now, my MPG might get better. The plugs really needed replacement at 35,000.
Old May 2, 2008 | 01:01 PM
scandal669's Avatar
scandal669
Default RE: PLUG change
dont forget the air filter and cap & rotor
Old May 2, 2008 | 01:04 PM
spencea15's Avatar
spencea15
no caps & rotor on a 4.7
Old May 2, 2008 | 01:09 PM
scandal669's Avatar
scandal669
ahhhh ok, didnt know that
Old May 3, 2008 | 01:25 PM
jisco's Avatar
jisco
Hello!
I've only been a dodge owner for about 4 1/2 weeks and am in the learning stages.
I have the 4.7 in an 01 quad cab with approx. 67400 Miles.
Yesterday I replaced the front shocks,"BIG" difference.
Anyway if you don't mind, what plugs and PCV valve did you use?
Thanks for your time,
jisco
S.E. Ohio
Old May 3, 2008 | 02:28 PM
Jr. Mechanic's Avatar
Jr. Mechanic
ORIGINAL: jisco
Hello!
jisco
S.E. Ohio
Best plugs to use are the autolite 3923's.
Old May 3, 2008 | 05:57 PM
Brummo's Avatar
Brummo
yes, I used the autolite platinums, and a fram pcv valve. lloks just like the mopar one.. Found it at Oriley AUto parts. Advanced auto couldn't get one they said I'd have to got through Dodge. WRONG! Got it for about $3.89. Wasn't bad to change. Just make sure you turn counterclockwise and pull back, Out it came.
Yup, no cap and rotor on this bad boy. nothin' like Direct Ignition.
Hope my milage gets better.
Old May 3, 2008 | 10:55 PM
Jr. Mechanic
Ugh, please tell me you didn't use platinum? I guess it is your truck, but on these magnum motors, you will see a 2mpg decrease with platinum plugs, and it will not run as well...
Old May 5, 2008 | 12:31 PM
Brummo's Avatar
Brummo
Didn't think mileage could get any worse.
How do the plats differ from the regular when it comes to mileage? Do they not spark hot enough or what? Pulled my boat and didn't notice anything out of the ordinary. Mileage has been ok. got 14.8 average pulling yeaterday, Had a little tail wind on the way home. The mileage comp was giving me about 15 on the way to the lake about a 70 mile tow away.
I've never had problems in other vehicles with the platinums. Any more info on that for me on platinum vs. reg plugs?
Old May 5, 2008 | 12:42 PM
dualdakota01's Avatar
dualdakota01
what plugs should be used on the 4.7?
