high engine rev at start up
Old May 11, 2008 | 05:44 PM
dojman's Avatar
dojman
Default high engine rev at start up
Hi I have a 2000 dakota 3.9l v-6. When I start my engine cold it usually revs to almost 2000 rpm before dropping to normal. Any ideas how to fix this? thx
Old May 11, 2008 | 05:58 PM
scandal669's Avatar
scandal669
Default RE: high engine rev at start up
its the choke and it is that way to naturally warm up the engine...its normal. let it be for a minute and then hit the gas real quick while in neutraland the rpm's should come down...if not, then spray some carb and choke cleaner all over the outside of the throttle body concentrating on the choke area and throttle linkage.
Old May 11, 2008 | 06:38 PM
f0x672's Avatar
f0x672
theres no chokes on these trucks, they are fuel injected, clean your IAC (intake air control) solenoid for a first step, its on the throttle body
Old May 11, 2008 | 08:16 PM
varsis's Avatar
varsis
Im sure mine revs to 2k than drops almost right away though.. Just right when you start it though.
Old May 12, 2008 | 08:08 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yea i think mine jumps when you first turn the key too, but then it drops to 900-1000(when cold) until it warms up some then drops to like 500+/- but i have the 4.7, im pretty sure my dads truck jumps up there and falls back down when you turn the key too tho (he has the 3
Old May 12, 2008 | 12:04 PM
swalinemx's Avatar
swalinemx
On the 4.7, rev'ing to 2000 rpm is not right. I agree, clean the IAC or replace it along with the TPS.
Old May 12, 2008 | 12:40 PM
Loud Pedal's Avatar
Loud Pedal
The Total Package
i have the 4.7 and it only goes to 1800 and quickly calms down to 500-700 reguardless of the weather
Old May 12, 2008 | 01:34 PM
scandal669's Avatar
scandal669
ORIGINAL: f0x672
that was what i meant...
Old May 12, 2008 | 02:59 PM
shrpshtr325
THE ULTI-MOD
yea i payed attention to what mine spikes to when i turn it on and its more like 1200-1300 then comes back down relatively quickly(but its in the 60s-70s here so its kind of warm)
Old May 20, 2008 | 11:12 PM
dojman's Avatar
dojman
Hi if I replace the IAC can I get one from an autowrecker or do I need a new one?
