97 Wheel Hub Help
Old Jun 1, 2008 | 07:27 PM
mystakilla's Avatar
mystakilla
Default 97 Wheel Hub Help
Trying to replace the Assembly hub on the front passenger, removed the axle nut along with the 3 knuckle bolts, ive been trying for atleast 2 hrs now to get the hub off, tried solvents, heating, pounding on it, whats the deal here? do i need a special tool or something?
Old Jun 1, 2008 | 10:22 PM
440shadow's Avatar
440shadow
Default RE: 97 Wheel Hub Help
after you remove the caliper, rotor, the axel nut, and the 3 hub bolts it should pull right off. you may need to bang it a little with a soft hammer to knock it loose. if that does not work you will need a three armed gear puller. good luck and let me know how you make out.
Old Jun 2, 2008 | 01:01 PM
mystakilla's Avatar
mystakilla
After a bottle of deep creep and a proper chisel i managed to get it off. . . thanks for help though, now another problem. . . see new post.
