Removing the head
Old Jun 4, 2008 | 12:46 AM
imjustagirl's Avatar
imjustagirl
Default Removing the head
My father in law is working on an 01 dekota 4.7L engine. He wants to know if you can remove one head without removing the front timing cover? And ifso how can you work around the timing chain??Thanks!!
Old Jun 4, 2008 | 10:49 AM
steve05ram360's Avatar
steve05ram360
Default RE: Removing the head
welcome to DF...
you'll have to remove the chains... there is a DIY writeup on it that I saw once upon a time, I think I found it while searching for the HO heads for that motor. let me see if I can find it
Old Jun 4, 2008 | 10:57 AM
steve05ram360
cam swap... gets you part of the way...
http://www.paysonarizona.net/MyProjects/ProjectDak/Project_Dakota_HO%20Cams%20Swap.htm
http://www.bionicdodge.com/Download/...ms_Install.pdf
didnt find anything specific on the head but this will help...
Old Jun 4, 2008 | 01:48 PM
00DakR/T's Avatar
00DakR/T
Yeah, you can't remove the heads without pulling the front timing cover. There really isn't much to getting everything off, although the cam bolts will be a pain to remove without an impact and I use a special tool to hold the timing chains in place to keep from having to retime the whole thing. If you read through that write-up and still have any questions just give me a shout and I will try to help you out.
Old Jun 4, 2008 | 08:32 PM
RoaminGnome's Avatar
RoaminGnome
What did you use to keep things in place so you didnt have to retime? That will save me time and a big headache. Feel free to PM me
Old Jun 9, 2008 | 09:53 PM
imjustagirl
Hey Thanks everyone. What is the tool to hold the timing chains in place? Do you have a part # and approx cost? Or where can I get one? Thanks again!
