Map sensor connector
Old Jun 4, 2008 | 01:22 PM
rixlum's Avatar
rixlum
Default Map sensor connector
Hi All; Need info on how to disconnect the connector on the map sensor. I have an aftermarket part to enhance my fuel mileage and need to splice into the connector. Also need to find a wiring diagram for my '01 Dakota so I can verify what each wire is. Right now the 3 wires looking from front to back is a=orange, b=brn/grn, c=darkblue/vt, I believe. My eyes aren't like they use to be. Colors could be different. I do know that a=orange. Any Help would be greatly appreciated.
Old Jun 4, 2008 | 01:44 PM
00DakR/T's Avatar
00DakR/T
Default RE: Map sensor connector
Orange is the 5 volt supply wire, black/light blue is the sensor ground, and dark green/red is the sensor signal circuit.
I would not recommend modifying sensor data like this as it is mroe than likely not going to cause any increase in fuel mileage and has a very real risk of cuasing PCM problems. If you really want better gas mileage my suggestion is get a beater or buy a bike.
Old Jun 5, 2008 | 05:23 PM
rixlum's Avatar
rixlum
Thanks for the info. The way I'm going to install it won't be permanent. Just splice into the wires. How do I disconnect the connector? I don't want any damage to the connector.
