code p-0455
Old Jun 19, 2008 | 05:49 PM
dodgewilltravel's Avatar
dodgewilltravel
Default code p-0455
Had a code come up this morning going to work p0455 what the H is that. I disconnected the neg and turned the key three times and no more code, it will come back in time, but should get it fixed.
Old Jun 19, 2008 | 09:06 PM
00DakR/T's Avatar
00DakR/T
Default RE: code p-0455
I believe that code is for a medium EVAP leak. I'd check you vacuum hoses real good, including the ones under the truck. Odds are thats where they will be.
Old Jun 20, 2008 | 11:10 AM
i2kdave's Avatar
i2kdave
According to the code list on this forum, it's actually a large leak. I had the same problem about 2 weeks ago and the hose had come loose from the charcoal canister. If you crawl under the truck by the driver's side door, it's a black plastic box with a couple of hoses connected to it.
