98 3.9 recently gutless!!??
Old Jun 22, 2008 | 01:47 PM
nottellinu's Avatar
nottellinu
Default 98 3.9 recently gutless!!??
new to dodge,just bought my truck a few months ago,ran like a champ.recently have lost alot of power and milage.did a tune up and nothing changed.only code found is an evap leak,did not believe this to be part of the problem,gonna smoke test the vacuum system anyways.would love to change fuel filter but not into payin 200 for a new pump,very bad design idea.any ideas how to eliminate the onboard filter and install an inline filter with check valve to help with bleed down??
Old Jun 22, 2008 | 11:52 PM
varsis's Avatar
varsis
Default RE: 98 3.9 recently gutless!!??
o2, cat evap i would check it out, did the code come on than you had the problem? Sounds like fuel or spark or too much back pressure.
Old Jun 26, 2008 | 10:32 PM
crusing52's Avatar
crusing52
Might want to check out the egr valve also.
