}Project{ Battruck
Old Jun 29, 2008 | 05:24 AM
batman13's Avatar
batman13
Default }Project{ Battruck
alrighty boiz,
here we go.
working hard so limited pics as i go.
im currently have the tanks bolted directly to my spare mount, i don't have the luxury of a welder so it'll work, once i pull the bed to do the bags i'll weld up some official brackets out of angle stock.
heres where my comps are going, nice and safe
what air tanks sir?
dak-1
drill bit-1
this bit was never used when i started, broke my good one so i used this to do the last 4 holes, got a little hot on the final hole, it was glowing
i got the hole done though lol
i am hoping to have a fully functioning air system by the end of the week.
at least enough to run a hose off of. and no leaks
Old Jun 29, 2008 | 09:56 AM
jonnymagnum's Avatar
jonnymagnum
Default RE: }Project{ Battruck
thats some good progress, cant wait to see it all done
Old Jun 29, 2008 | 02:21 PM
batman13's Avatar
batman13
i hate cheap tools, just had to get a new cut-off since i trashed my old one,
and now i can't find any decent drill bits, the one im using to do the holes for the comps is dull and i didn't get 1 hole done with it
Old Jun 29, 2008 | 02:24 PM
Loud Pedal's Avatar
Loud Pedal
The Total Package
damn batty....i hope you spend some TLC on that undercarrige to clean it up.....that looks like it has been on a salty road since it was built
Old Jun 29, 2008 | 02:38 PM
batman13's Avatar
batman13
actually no, its only been in ohio 5-6 years,
texas before that
but yes, it will get a thorough grinding/undercoating after i get all the welding done,while the beds off, no point doing it now, when i'll just grind it off, then redo it a few times
Old Jun 29, 2008 | 03:49 PM
wink2873's Avatar
wink2873
you know, i dont understand how the underside of my truck looks so nice. i live in northern ohio and winters are pretty bad, but my truck basically looks like it did when it rolled out of the factory, the only thing i do is spray underneath every time i wash.
Anyway, are you going to fix that part of your truck thats all smashed in and paint it all the same color? Nice job so far, is that gonna be sitting on the ground when you're done?
Old Jun 29, 2008 | 04:54 PM
batman13's Avatar
batman13
yea, its gonna sit on the ground,
i've always washed my undercarridge weekly in winter esp.
i'll do the damage when i do all the rest of the body mods, next summer most likely.
UPDATE:
got the right comp bolted up, hooked to rear tank and filter installed/line run behind taillight. all is left is to wire it up
pics after the monsoon is done
Old Jun 29, 2008 | 05:15 PM
batman13's Avatar
batman13
filter, nice and dry spot
next time i'll install the comps BEFORE the tanks. or at least drop the tanks. but they're in so damn tight i didnt even bother
Old Jun 29, 2008 | 10:49 PM
Loud Pedal's Avatar
Loud Pedal
The Total Package
damn u sure do have you mind set on this.....
Old Jun 29, 2008 | 11:07 PM
RoaminGnome's Avatar
RoaminGnome
Looking good. I cant wait to see it sitting on the ground
