radiator hose exploded
Old Jun 29, 2008 | 08:55 AM
msconnol's Avatar
msconnol
Default radiator hose exploded
My Dodge DakotaSLT v6 3.9 liter truck was overheating and then the radiator hose exploded in half. So I went to checkers auto parts and purchased the cap to engine and lower upper radiator hoses. They did not come with the pressure cap on the cap to engine hose. What do i do? Also I found a long rusted spring after the hoses exploded???where did it come from. Thanx hope u know
Old Jun 29, 2008 | 09:14 AM
2001DodgeMan's Avatar
2001DodgeMan
Default RE: radiator hose exploded
Didn't you try other auto parts stores for the correct hose with the pressure cap on it? I would have gone the local dealer for that part if the other stores didn't have it(or gone online and looked for the correct part and order it that way)
Old Jun 29, 2008 | 10:05 AM
albose's Avatar
albose
If you didn't have a cap on the old hose,why need one now?The spring you found comes from inside the hose,it keeps it from collapsing.
Old Jun 30, 2008 | 05:01 AM
User's Avatar
User
you will more then likely need to go to the dealer to get the hose with the cap, when i replaced mine, napa nor autozone had the factory style, got mine from the dealership for about 20$ i think, lower hose you can get from anywhere. Spring came from inside the hose.
Old Jun 30, 2008 | 05:37 PM
2001DodgeMan
The hose that exploded HAD the cap on it. There are advantages to having that pressure cap.
Old Jul 1, 2008 | 06:40 PM
moe7404's Avatar
moe7404
moe in wichita ks
thats why i run the cooling system with no pressure, under pressure its a big leek but unpressureized it just small leek.
