cam swap help
Old Jul 1, 2008 | 07:35 PM
mikedasniper2000's Avatar
mikedasniper2000
Default cam swap help
hey i just swaped out my stock cam with a 255 intake 265 exhaust street/strip cam ive got it all back together but it wont start the engine turns over but its not firing i checked the timing chain to make sure the cam and crank where in sync and they are the distributor bounces back and forth so i though it was out of the gear but its not and the rotor spins with the engine. all the wires are right and plugs are good does any one have any idea whats up?
Old Jul 2, 2008 | 06:40 AM
wink2873's Avatar
wink2873
Default RE: cam swap help
did you make sure your cam and crank sensors are in place
Old Jul 2, 2008 | 04:36 PM
moe7404's Avatar
moe7404
moe in wichita ks
sounds like the dist shaft is bend, or the gear is not stright.
