squeaking noise
Old Jul 23, 2008 | 06:18 PM
lamchop's Avatar
lamchop
Default squeaking noise
I just got this truck, its an 2004 ext cab, I thought this would be an easy fix but I am a little stump, the squeaking will happen when I give it gas, or when i stop, i can shake the truck hard and make it squeak,the noise is coming from the cab, the things that I did already is tighten the 6 body mounts on the cab, i also spray then with silicone, I have step bars which I have tighten, the squeaking is still there, what else can I check?
Old Jul 23, 2008 | 06:24 PM
f0x672's Avatar
f0x672
Default RE: squeaking noise
it's in your suspension, most likely the bushings are worn, dry, and the rubber is rotting. in some instances the ball joints may squeak if they are worn from a lack of grease. check all the moving parts in the suspension
Old Jul 23, 2008 | 06:29 PM
lamchop's Avatar
lamchop
When I had the truck on the lift I also spray silicone on almost everything that I saw would move or have some type of rubber. I didn't look into the front of the truck meaning the balljoint, tierods, etc. these parts on this truck can make a squeaking sound? I know they will clunk or bang. thanks, I will look into that when I get a chance to but her back on the lift. for now I guess I have to trun up the radio.
Old Jul 23, 2008 | 06:59 PM
f0x672's Avatar
f0x672
it could be a bushing in the shock mount, a lot of looking over and paying attention to detail, more than likely a bad bushing versus a tie rod or a ball joint
