manual r/t???
Old Jul 25, 2008 | 09:57 AM
1d9a9k3ota's Avatar
1d9a9k3ota
Default manual r/t???
did dodge put a manual tranny in the 2wd 5.9l r/t's? every one ive ever seen it automatic.
Old Jul 25, 2008 | 10:36 AM
dragon8master's Avatar
dragon8master
Default RE: manual r/t???
no
Old Jul 25, 2008 | 06:29 PM
bpark8824's Avatar
bpark8824
no sir, all automatics. It seems all performance trucks are like that. The Ford Lightning is auto, S10 Extreme is auto, Pretty sure the old 454 chevy 1500 was auto too. Probably because they dont make enough...? Not real sure.
Old Jul 25, 2008 | 06:33 PM
Frenchy's Avatar
Frenchy
The SRT10 Ram is a stick.
Old Jul 25, 2008 | 06:46 PM
bpark8824's Avatar
bpark8824
really? did not know that. All of themor were some auto some stick?
Old Jul 25, 2008 | 09:44 PM
rtdakota2001's Avatar
rtdakota2001
i would be in dakoa heaven if they put a beefy 6 speed behind my R/T......
[sm=grinangel.gif]
Old Jul 25, 2008 | 11:19 PM
Natedogg625's Avatar
Natedogg625
ORIGINAL: bpark8824
only the regular cabs came w/ a stick
the quad cabs got a ****ty 4 speed auto...
Old Jul 26, 2008 | 02:14 AM
User's Avatar
User
The 5.2 Sports came with the option to get a NV 5 speed. And the Auto 46re that was put with the 5.9 R/Ts had a high HP/TQ % Cut about 22% to the avg 15-18% to all other trannys, after the 5.2 and NV 5 speed to the 5.9 46re they both put down about the same amount of HP to the rearend.. its sad.
But the 5.9 is the same block as the 5.2 and you should be able to bolt on a 5 speed out of a 5.2 to the r/t, many people have done it, and if you want to get techincal and sick at the same time, you can do a viper 6 speed, but thats a bit more work.
Im not postive but i think the 5 speed with the 5.2s are the NV4500s. If you want to start looking for one.
Old Jul 26, 2008 | 08:59 AM
rtdakota2001
anyone done the NV 5 speed sawp into an R/T? now you got me curious user..... i wonder how much of a cluster f*** it is?
Old Jul 26, 2008 | 10:59 AM
User's Avatar
User
ORIGINAL: rtdakota2001
not hard at all, only thing that would suck is cutting the floor to put in the shifter.. other then that everything should hook right up.
