Whats the fix for these codes?
Old Jul 26, 2008 | 03:18 PM
dako85's Avatar
dako85
Default Whats the fix for these codes?
My CEL is on and I got these codes
P0713 (M) Trans Temp Sensor Voltage Too High Voltage greater than 3.76 volts (4-speed auto. Trans. Only).
P0753 (M) Transmission 3-4 Shift Soleniod/Transmission Relay Circuits An open or shorted circuit detected in the overdrive solenoid control circuit or trans relay circuit in JTEC RE transmissions . Was MIL code 45.
P1763 (M) Governor Pressure Sensor Volts Too High Voltage greater than 4.89 volts. (4-speed auto. Trans. Only)
P0113 (M) Intake Air Temp Sensor Voltage High Intake air (charge) temperature sensor input above the maximum acceptable voltage.
How can I make her all better?
Old Jul 26, 2008 | 05:29 PM
User's Avatar
User
Default RE: Whats the fix for these codes?
Sounds like you have a short in your harness.
User's Avatar
User
Check a wire diagram and get a multimeter.
User's Avatar
User
Sorry its only letting me post short posts cant put it all in one.
Old Jul 26, 2008 | 11:53 PM
dako85's Avatar
dako85
how would I go about it with the meter and fix the short?
Old Jul 26, 2008 | 11:56 PM
dako85's Avatar
dako85
I can only do short posts too, I do have a meter just dont know where to start
Old Jul 27, 2008 | 05:54 AM
User's Avatar
User
check the sensors throwing codes.. check for shorts to ground and shorts to voltage, first you will need to know the voltage it should be getting and figure out the wire colors and which ones are grounds.
Old Jul 27, 2008 | 08:46 AM
dako85's Avatar
dako85
the other odd thing is, when its running the lights flicker a little bit. could that be related?
Old Jul 27, 2008 | 09:00 AM
deezozdodge's Avatar
deezozdodge
HOW TO OBTAIN SERVICE MANUAL
Click on Dodge forum on the top menu
Scroll down and click on Dodge Intrepid
Scroll down and click 2nd Gen Intrepid
Scroll down and click on THE HOLY GRAIL
Then click on the link 2nd Gen LH service manual
from there you can download parts 1 and 2 of the manual.
You will need Adobe.
Old Jul 27, 2008 | 02:01 PM
dako85's Avatar
dako85
dumb question I guess but, will that help me for my dakota?
