5.2 motor swap, need help!!
Old Jul 27, 2008 | 11:04 PM
kanner1's Avatar
kanner1
Default 5.2 motor swap, need help!!
Hi,
Roght in the middle of pulling the 5.2 from my truck.
Got everything but 2 converter bolts. I cant get at them & cant seem to spin the motor (may be locked up).
Anybody got any ideas?? The new motor is ready & waiting. I dropped my tools to come post this looking for an answer!!!!
Thanks,
Steve [align=right][/align]
Old Jul 28, 2008 | 11:07 AM
yellowjacket99's Avatar
yellowjacket99
Default RE: 5.2 motor swap, need help!!
What have you tried to get it to rotate?
Old Jul 28, 2008 | 12:11 PM
kanner1's Avatar
kanner1
tried the key & starter method, tried putting it in neutral & spinning it by hand even tried using a prybar on the flywheel gently. I just bought the big socket set & breaker bar for the balancer bolt will try that here shortly. I have the oil pan off so I can get at most rod bolts if that helps.
I am open to other thoughts, thanks.
Old Jul 28, 2008 | 12:29 PM
ironcowboy's Avatar
ironcowboy
I just did this on my truck, What it took was someone turning the engine with the big socket and breaker bar, and someone holding the fly wheel with a screw driver... Or if you can get a hammer claw and the sprockets and just pull down...
Old Jul 28, 2008 | 12:43 PM
kanner1's Avatar
kanner1
OK I WILL GIVE IT A TRY, THANKS.
Old Jul 28, 2008 | 01:36 PM
rtdakota2001's Avatar
rtdakota2001
get a buddy to put on a REALLY TOUGH pair of gloves and hold the flywheel while you crank on it with a 3 foot cheater bar.
Old Jul 28, 2008 | 08:44 PM
984x4's Avatar
984x4
You do have the spark plugs out, don't you? Makes it a lot easier to turn motor over.
Old Jul 28, 2008 | 09:54 PM
kanner1's Avatar
kanner1
Nope plugs were not out-but they will be first thing in the am, also bought the 32mm socket & breakerbar tonight. So I'm gonna bust it loose or break something trying!
Old Jul 29, 2008 | 01:53 PM
varsis's Avatar
varsis
Yea breaker bar is the way to go I just took out my motor a few months ago and that is how I turned it over.
