Amp location
Old Jul 29, 2008 | 07:52 PM
ccrunner's Avatar
ccrunner
Default Amp location
Where the heck is the stock amp located? 2000 Quad cab.
Old Jul 29, 2008 | 08:46 PM
01SilverCC's Avatar
01SilverCC
Default RE: Amp location
It's behind the pastic trim panel in the frontpassenger's kick panel.
Jimmy
Old Jul 29, 2008 | 09:48 PM
Loud Pedal's Avatar
Loud Pedal
The Total Package
theres a stock amp in an 00 dakota????
Old Jul 29, 2008 | 09:50 PM
01SilverCC's Avatar
01SilverCC
In the ones with the Infinity sound system and separate tweeters on the front doors, yes.
Jimmy
Old Jul 29, 2008 | 09:56 PM
Loud Pedal's Avatar
Loud Pedal
The Total Package
oh.....damn.....what is you dont???? is there still hook ups for one...say if you have aftermarket door speakers adn you wanted to put an amp on them with out wireing the whole mess up????????
Old Jul 29, 2008 | 10:21 PM
crateampsrock's Avatar
crateampsrock
anyone know the specs of the factory Amp? would it be be able to run a 50 watt rms loudspeaker hooked to a PA system?
Old Jul 29, 2008 | 11:38 PM
ccrunner's Avatar
ccrunner
I'll ask my dad when he gets of the phone about the specs. What is the panel you are talking about on the passenger side?
Old Jul 29, 2008 | 11:48 PM
01SilverCC's Avatar
01SilverCC
It's the plastic panel on the right side down below the glove box. Down in the footwell area on the right side as you face forward in the truck. Open the passenger door look down at the inside edge of the door. The thin plastic piece you see covering the edge of the carpet is called the door sill cover. Follow it forward to the kick panel. The sill cover and kick panel are all a one piece part. Remove it by pulling out on the kick panel first then pull straightup on the door sill cover to remove the entire part. The amp is bolted to the metal behind the kick panel area.
Jimmy
Old Jul 30, 2008 | 01:14 AM
usmrocks's Avatar
usmrocks
ok, so i have a 97 club cab. there are the tweeter speakers on the door. does this mean i will have this stuff also? because my speakers sound horrible.
Old Jul 30, 2008 | 02:27 PM
ccrunner's Avatar
ccrunner
I think the amp is a 4x25. Pictures in my next post. I replaced the front with infinity kappas, going to get backs this week. Don't know which amp yet, although most likely a 4x75. The system now is so quiet. Thanks 01silver for the help. Usmrocks, I'm not sure if our system is the same or not, I would pull out your amp and see if our numbers match.
