Knock in Steering Intermittently
Old Aug 23, 2008 | 09:13 AM
jmich's Avatar
jmich
Hi DocZ,
I will try this as soon as I can. I heard from another guy that it could be the u-bolts (u-joints) on that as he had a similar problem.
Thanks,
Old Aug 23, 2008 | 02:27 PM
DocZ's Avatar
DocZ
It could be them.
You'll be able to feel them when you hold the shaft and have someone rock wheel while engine is off, you'll feel exactly where the play is located.
Grease helped removal almost all of the noise in my truck and friends but we're still changing the shaft.It's just nice to know that you're changing the right part first time out..lol
Old Aug 24, 2008 | 08:35 AM
2001DodgeMan's Avatar
2001DodgeMan
Sweet,love this forum as I can follow what's wrong ,then the process of diagnosing and if a similar problem occurs in my Dodge I know what to do about it and fix it.
Old Sep 1, 2008 | 02:45 PM
djr8505's Avatar
djr8505
New Member
I have recently fixed the problem with the knocking/popping in my wheel. It turns out that Dodge TSB 19-05-99 deals with realigning the steering column with the system. After the alignment, my issues were resolved.
Don
Old Apr 4, 2009 | 08:49 PM
72combo's Avatar
72combo
Originally Posted by djr8505
My 98 seems to have the same issues that you are describing. On of the things our Mech looked at was the steering link to the pump. If you happen to pinpoint the error let me know ok?
I had a 98 and because I worked at the Van plant for Chrysler and there was an issue with the u joints in the shaft and my 98 dakota was making the same little rattle noise and seemed to not be their sometimes. I took it to the dealer and told them what to look for they changed the intermediate shaft...in fact there was a TSB or maybe even a recall for that.
Old Apr 4, 2009 | 08:51 PM
72combo's Avatar
72combo
Originally Posted by DocZ
It could be them.
Its the intermediate steering shaft, my 98 and my 2000 both had them replaced almost as soon as I got them, could feel a weird jiggle in the steering wheel.
Old Apr 4, 2009 | 11:54 PM
magnethead's Avatar
magnethead
agreed, i may swap mine out too based on what it fels like down the road.
I was actuallt hinking bump steer in some of these other posts.... a bad heim or joint of any kind will play havoc with things.
Old Apr 5, 2009 | 07:00 PM
72combo's Avatar
72combo
Hey don't blame me if that doesn't fix your problem.........
