Differential woes
Differential woes
Hi
Well my 02 dak has got the howl> Would anyone know of a site where I can purchase the tool for adjusting the carrier bearings through the axle tube? Has anyone done the adjustments without the tool, or has anyone made the tool? I would like to do the job myself but if i can't find the carrier tool i might have to bring it to a shop.
Thanks in advance
First time dodge owner and not on a good roll, only had this thing for a month.
Thanks in advance
rtdakota
hey rtdakota no i don't plan on changing out the ring / pinion set just doing a bearing overhaul. it has a set of 3.55 in it and by looking at the wear pattern things look normal to me, i guess i will determin more when i actually confirm what the howl is coming from in the diff.
ya this really sucks as i run my 91 ford explorer up to this date and never had a diff/drivetrain problem. its to bad the body is falling off lol
hey,
one cheap thing you can do is just change the fluid. i had the same issue when i bought mine used. the diff fluid had never been changed in it and when i turned the truck at slow speed it would make a bizare sound. like a howl kinda. but yah i changed the fluid and made sure to add the friction modifier additive to it and it hasn't come back since. good luck tho.
dee.
dee.
