Problem while cruising sorta...
Old Aug 7, 2008 | 12:57 AM
varsis's Avatar
varsis
Default Problem while cruising sorta...
Okay here is the problem, when I am driving my truck, I can be driving all fine, I let off the gas it keeps going than when I go to put my foot back in the gas it will kind of jump down 400-500 rpm, and you feel it in the cab kind of like slam on the breaks for a second, or it missed a beat... lol. Everything seems to shift, fine no loss in power.
This has only happened to me since I swamped it. It does take a bit to start now though, but I think it may be a spark plug that takes a bit to warm up or something, because once it is started it runs nicely. I did however pull all the plugs and clean them before I tried to start it again.
I am thinking torque converter lock/unlock. I will try the plugs again, I went and cleaned them all but noticed no difference... I don't see the crank sensor causing this but someone correct me if im wrong. (Only happens when driving about above 60 km/h and let off and go again.)
Any ideas?
BTW changed the TPS, there was some oxidizing in the TB.
Old Aug 7, 2008 | 01:30 PM
varsis's Avatar
varsis
anyone?
Old Aug 7, 2008 | 03:12 PM
rtdakota2001's Avatar
rtdakota2001
just out of curiosity, which trans did you go with when you did the swap? maybe that will shed some light on the problem...
Old Aug 8, 2008 | 06:30 PM
varsis's Avatar
varsis
I kept the 42re in there. It shifts fine, I am going to replace the crank sensor and all plugs, I will see what happens.. I found a new crank sensor that is sealed...
Old Aug 10, 2008 | 07:51 PM
varsis's Avatar
varsis
replaced crank sensor all is fine now...
