00 Dakota Rear Window Actuator/Regulator
I have a 4 door Dakota, and my driver side rear window is not working, I pulled the door panel off and it seemd that when I took the actuator regulator not sure which one it is? It was tangled internally so I tore it apart and fixed that, and it was also disconnected on one side of the cable. One end is connected to the middle of the window, where is the other end connected? If someone has a diagram that would be extremely helpfull. Thanks
