Transmission issues - 2nd gear
Old Aug 14, 2008 | 10:43 PM
mnl001's Avatar
mnl001
Default Transmission issues - 2nd gear
I have an 03 Dakota with the 45RFE 4 speed transmission.
A shutter is being experienced at 30km/hr (19 m/hr) when it changes to second gear. I believe this is either a bad seal or piston problem, the next part is confusing. If I perform a relatively fast stop (after the vehicle has surpassed 30km/hr) the vehicle shutters again 2 seconds after coming to a complete stop.
Would anyone have any input?
Thanks
Old Aug 14, 2008 | 11:14 PM
varsis's Avatar
varsis
Have you tried changing the filter and fluid>
Old Aug 14, 2008 | 11:18 PM
mnl001's Avatar
mnl001
I changed the fluid and filter about 3000 miles ago. Used at+4 fluid.
Old Aug 15, 2008 | 04:21 AM
varsis's Avatar
varsis
check for codes and see if you can narrow it down, if you have a DRB that will help too.
Other wise I would think this is either like you said or a valve body problem. Could even be a clogged up electronic.
