R&R Transmission
Old Aug 16, 2008 | 06:25 PM
troy00690's Avatar
troy00690
Default R&R Transmission
Well last the tranny went out. My dad and I replaced it with one that had 45k on it. The whole project went pretty smooth. There were a few times we asked out selves what was dodge thinkin when they did it this way. Well got it off the jack stands and filled it with fluid and off we went. Works great. Will need to replace the upper bank O2 sensor. Busted the clip trying to take it apart. Figured on the last one I would figure out how they work.
Old Aug 16, 2008 | 07:14 PM
TheePlaymaker's Avatar
TheePlaymaker
that's awesome that everything went pretty smooth and worked out and i know what you mean with that what the hell was dodge thinking when i did my slave, master and hydraulic lines for the clutch the other day.
Old Aug 16, 2008 | 07:24 PM
Loud Pedal's Avatar
Loud Pedal
The Total Package
im abotu due for a trans....mine has 185309 miles on the OD and it dosent have the punch like it did at 171,000.....soo if anyones got a trans for a (see my sig)......please let me know
Old Aug 16, 2008 | 08:59 PM
troy00690's Avatar
troy00690
I picked mine up from a dodge truck wreckers for 750. Had 45k on the clock. Could have got the low mileage (3K) for 950. Since I had to borrow money for the fix I wasn't going to push my luck. Now it is time to save for tires.
Old Aug 16, 2008 | 09:56 PM
varsis's Avatar
varsis
awesome, I found the transmission in my truck a real pain to remove however, im sure it would have went a lot smoother if I had a transmission jack. 4wd is a lot more complicated... Did you remove the one way valve?
Old Aug 17, 2008 | 11:50 AM
troy00690's Avatar
troy00690
We had an ATV jack that we used as a trans jack. I am not sure where the one way valve was. We put everything back on that we took off.
Old Aug 17, 2008 | 06:44 PM
Loud Pedal's Avatar
Loud Pedal
The Total Package
wheres this????
Old Aug 17, 2008 | 07:32 PM
f0x672's Avatar
f0x672
when i had my trans rebuilt, it would of been about $600 for the heavy duty soft parts with a converter and the one way check valve removed. but since i pretty much grenaded the trans, but in the end with only the case from the trans with all new hard and soft parts plus a HD converter, ran me $2500 plus the aux. cooler install. strongest dodge automatic ive ever come across. over 30K on it, still shifts and lays the power to the axles like brand new still.
Old Aug 17, 2008 | 08:37 PM
Loud Pedal's Avatar
Loud Pedal
The Total Package
Originally Posted by f0x672
when i had my trans rebuilt, it ran me $2500 plus the aux. cooler install. strongest dodge automatic ive ever come across. over 30K on it, still shifts and lays the power to the axles like brand new still.
damn!!!! i really dont want to throw down 2500 for an automatic....i would for a BUILT UP 5/6 speed
Old Aug 17, 2008 | 11:24 PM
f0x672's Avatar
f0x672
it's well worth it for the peace of mind and the fact it's all heavy duty internals. plus the guy had to replace pretty much everything except the case. the overdrive unit was shot to hell. a salvaged case would of been an additional $500 if he couldn't break the overdrive unit off the tail of the case, nice right?
