Lowering the rear...
Old Aug 30, 2008 | 07:47 PM
lucas3397's Avatar
lucas3397
Default Lowering the rear...
Does anyone know where I can get some drop shackles for the rear on a 2003 Dakota 2wd? I have searched quite a few places but cant find any shackles. I can just find lowering blocks. If blocks are the only way to go how bad is the ride with 2" lowering blocks for the rear?
Old Aug 30, 2008 | 07:52 PM
varsis's Avatar
varsis
Don't get blocks. They suck. Maybe fab your own up./
Old Aug 30, 2008 | 08:47 PM
jonnymagnum's Avatar
jonnymagnum
belltech makes 2" lowering shackles im pretty shure
Old Aug 30, 2008 | 09:51 PM
MTN13's Avatar
MTN13
From: Hometown= Highland Michigan School= Lima Ohio
i have 4" lowering blocks in my truck and i don't think they ride that bad. but when i was looking for a kit i found shackles on summit motorsports website.
Old Aug 30, 2008 | 10:04 PM
varsis's Avatar
varsis
well blocks can collapse and cause some nasty problems, thats the only reason why I would stay away from them. Shackle is so much better,,, Thats what im doing with leafs, might get some blocks to level it out at first till I get money for everything as my swap is costing a lot...
Old Aug 31, 2008 | 05:34 AM
User's Avatar
User
Aluminum blocks on a V8 can collapse, on a v6 they are fine.
Use Steel Blocks on v8s and you will be fine.
Blocks are not bad, and work just fine and are a hell of alot easier to install then shackles.
I have 2in steel blocks on mine and it rides fine, but i also replaced my shocks with Toxic Drop Shocks, so it rides a bit more rough now and not as bouncy
