Egr
Old Sep 18, 2008 | 03:39 PM
rtdakota2001's Avatar
rtdakota2001
Default Egr and intake ???
do i have it and what the hell is it?
Old Sep 18, 2008 | 03:55 PM
TheePlaymaker's Avatar
TheePlaymaker
not sure if this is what your talkin about its all i could find on it though http://en.wikipedia.org/wiki/EGR
Old Sep 18, 2008 | 07:11 PM
varsis's Avatar
varsis
i don't think you have it. it's more of a older dak one.
Old Sep 18, 2008 | 07:17 PM
f0x672's Avatar
f0x672
exhaust gas recirculation..... yeah i doubt you have it... those systems are a b*tch to work with on the cummins ISXs... pita
Old Sep 19, 2008 | 04:24 AM
User's Avatar
User
You don't have it... i think it was gone with after the 95+ years, maybe sooner not sure, but i know for a fact you don't have it.
and its exhaust gas recirculation = EGR, like said above.
Old Oct 7, 2008 | 09:39 PM
rtdakota2001
there is a significant difference between these intakes on summit. both seem to be what im looking for except one is EGR and therefore more expensive. part #'s DCC-5007398AB & DCC-5007790. which one should i go with???
Old Oct 7, 2008 | 09:52 PM
JetNoise's Avatar
JetNoise
Get the one without EGR.
Your truck doesn't have and EGR. Consider yourself lucky.
Old Oct 7, 2008 | 10:16 PM
wink2873's Avatar
wink2873
you dont have EGR, they ended around 96, my hughes stage 1 manifold that was a customer supplied core came with a EGR hole, but hughes put a block-off plate on it.
Old Oct 7, 2008 | 11:19 PM
00DakR/T's Avatar
00DakR/T
Anybody else think its interesting that adding hot exhaust gas to the intake air actually COOLS the combustion temp?
Old Oct 7, 2008 | 11:45 PM
f0x672's Avatar
f0x672
it does actually... the exhaust gas is cooled down from all the pipe work to the intake, then once it enters the cylinder, it takes away from pure fresh atmospheric air (remember it's not all oxygen) causing less of a combustion which will cause cooler cylinder temps, less fuel used = less emissions. and to make it simple, otto engines were never designed to be compatiable with emission controls like EGR or ACCERT on the Caterpillar engines.
