valve cover leak
Old Sep 18, 2008 | 06:51 PM
batman13's Avatar
batman13
Default valve cover leak
ok, so now that i have my DL back i find a new problem...
my valve cover leaks, i've tried several times to fix the rubber seal with no avail,
the gasket is fine, it just never stays in place as i install the cover
any ideas,
or if i could use a silicone tube type, we use it at work because it seals better than the standard gaskets
any ideas let me know
Old Sep 18, 2008 | 07:08 PM
varsis's Avatar
varsis
i wouldn't mess with silicon gaskets might get it into the engine. Make sure the gasket it clean than maybe use a little bit of gasket sealer. and put it on top only, just to hold the gasket to the cover.
Old Sep 18, 2008 | 07:13 PM
batman13's Avatar
batman13
i gotta do something...
thats what i was thinking of doing, i wasnt sure about crap getting into the engine, but i learned a leaky valve cover does seem to cause vacuum issues
Old Sep 18, 2008 | 07:14 PM
f0x672's Avatar
f0x672
just make sure the surface of the head and cover are clean, wipe off the gasket and torque that mother down... to spec at the most... and silicone is only good for one thing... implants, haha. just like how i remember the firing order for a diesel inline 6, 15 is too young, 36 is too old, 24 is just right... 1-5-3-6-2-4
Old Sep 18, 2008 | 07:29 PM
batman13's Avatar
batman13
thats how i've done it twice already, but the rubber gasket does not cooperate,
i'll just do the stick it to the cover trick,
but the cloud of smoke trailing me does keep tailgaters off my ***...
Old Sep 18, 2008 | 08:19 PM
varsis's Avatar
varsis
yea might do that but won't help you when your engine blows of oil starvation...
Old Sep 18, 2008 | 08:22 PM
batman13's Avatar
batman13
yea....lol
i'll stick with throwin sparks...
Old Sep 19, 2008 | 03:39 PM
batman13's Avatar
batman13
well i went ahead and grabbed a tube of gasket sealer, and some restore just cause,
so once D'kota chills out a bit i'll go ahead and fix the gasket, then its back off to school to see if it works...it better
Old Sep 19, 2008 | 04:42 PM
varsis's Avatar
varsis
Hope you get it fixed. I hate when **** like that happens.
Old Sep 19, 2008 | 04:49 PM
batman13's Avatar
batman13
ok, fixed, gave it a good RPM test, sealed tight....
