crank and bearings
Old Sep 23, 2008 | 08:21 PM
macandhoneymz@msn.com's Avatar
Default crank and bearings
Gonna pull the motor this week, decided from the advice it's better this way, can an experience mechanic tell me any advice in replacing the crank and rod /main bearings before I get started. Did a ford motor yrs back so I'm not afraid, just want to make sure I've got everything ready. thx mjz
Old Sep 23, 2008 | 09:28 PM
f0x672's Avatar
f0x672
while it's out i'd definitely replace your front and rear main seals
Old Sep 24, 2008 | 01:55 AM
varsis's Avatar
varsis
might as well rebuild the motor if your going to the trouble... rings aren't that expensive... Check all your rods ect... Whats bad replace, while heads are off check values too.
