Anybody know what this is?
Old Sep 24, 2008 | 08:30 PM
Spike300's Avatar
Spike300
Question Anybody know what this is?
Drivin my truck, it willjerk alittlleitseemslikethen it will stopmight sart again. It will only be three or four little jerks. Somes days it won't do it at all. So i was wondering what itmight be. Im afraidit the tranny but i hope not. If any of u want to know more about it let me know i thank u for all the help.
Old Sep 24, 2008 | 08:35 PM
Loud Pedal's Avatar
Loud Pedal
The Total Package
not to be a dick...but add some spaces in where there needed...and completely describe the problem
Old Sep 24, 2008 | 08:59 PM
spencea15's Avatar
spencea15
Please describe the problem better and use the space key.
With out knowing much, How many miles? Do you have a limited slip rear diff? When was the last time it was serviced? If it has a limited slip did you add the additive? The rear diff's with limited slips can have problems just as bad as the tran. Also when was the last time the tran was serviced?
Old Sep 25, 2008 | 12:00 PM
Dodge Rules's Avatar
Dodge Rules
More info would be nice. Give all the details of the truck. Then give all the details about the problem, any issues that will make giving you feedback alot easier and we will be able to solve the problem.
Old Sep 27, 2008 | 07:26 AM
mnl001's Avatar
mnl001
If I had to guess - what is being said, the vehicle shutters when shifting gears from first to second and also down shifting. - Sometimes anyway.
Most common is a sticking Solenoid Switch Valve that controls line pressure in the tranny. this solenoid is only used in this sequence.
This starts out intermittently, then gets more regular.
The L/R pressure switch is monitored in the tranny to confirm SSV movement. If the movement is not confirmed (the L/R pressure switch does not close), 2nd gear is substituted for 1st. A DTC will be set after three unsuccessful attempts are made to get into 1st gear. I beleive this will account for the three jerks you are feeling.
Old Sep 28, 2008 | 02:53 PM
Spike300's Avatar
Spike300
Originally Posted by Spike300
Drivin my truck, it will jerk a littlle. then it will stop, might sart again. It will only be three or four little jerks. Somes days it won't do it at all. So i was wondering what it might be. Im afraid it the tranny but i hope not. If any of u want to know more about it let me know i thank u for all the help.
Sorry bout the spaces. I just had the trany put in abot 7500 miles ago. Im thinking i might need new plugs and wires becasue it does miss. and don't worry i got them but just need to put them in. all i can say is that it jerks a bit thats all i can say it is
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
