O2 sensor signal wire
Old Oct 2, 2008 | 03:24 PM
99dakota318's Avatar
99dakota318
Default O2 sensor signal wire
I have a 99 dakota with the 5.2 and need to know the the color of the wire comming from the upstream O2 sensor to the pcm. I have looked in the haynes book, it tells me a tan/white wire but it isnt there so im stumpt. any help would be awesome
Old Oct 3, 2008 | 12:10 AM
00DakR/T's Avatar
00DakR/T
According to dealerconnect, it should be a orange and tan
Old Oct 3, 2008 | 02:24 AM
varsis's Avatar
varsis
check the pin number... Unless you are looking for it somewhere else...
Old Oct 5, 2008 | 11:53 AM
00DakR/T's Avatar
00DakR/T
That diagram is for a 5.9 which is different from a 5.2. The 5.2 doesn't have any bank 2 sensors
Old Oct 5, 2008 | 01:00 PM
99dakota318
Yeah 00dakrt I see what you are saying but I think you are right with the orange/tan wire...The only issue is it contently reads around 700-800mv and sometimes jumps over a volt all with no codes... I want to run my hydrogen kit but to do that i need to add voltage to the sensor with an efie and with it running so rich it makes more problems. hmmmm....
Old Oct 6, 2008 | 12:14 PM
00DakR/T's Avatar
00DakR/T
Well the sensor itself will only produce roughly 1 V. The PCM biases that signal with a 2.5V bias voltage. If you were to read the voltage with a scanner it should show between 2.5 and 3.5V but the signal is also constantly changing and while a voltmeter will show 700-800mv, its actually an average. The sensor really produces what looks like a sine wave.
Old Oct 7, 2008 | 11:25 AM
99dakota318
Thanks thats some really good info that will come in handy.
